Old 01-30-2021, 07:35 PM
konfla konfla is offline
I’m not sure I understand why I would need the wire harness. All the sensors now connect to the micro tech. Wouldn’t they just switch over to the ms3? Also the micro tech runs mostly off the vacuum pressure, does megasquirt even use a vacuum connection?
And with my luck, it will turn out to be something else was the problem all along like a faulty IAC valve.
