Old 02-01-2021, 06:00 AM
strictlypersonl strictlypersonl is offline
The axle must be pressed out of the hub. That can be easy or difficult depending on the original clearance and whether Loctite was used when the parts were assembled. Unfortunately, you won't find out until you try.
There should be a spacer and shims between the inner and outer bearing cones. Reassemble the same way (assuming the end clearance was correct in the first place).
