Old 02-04-2021, 03:37 PM
Tommy's Avatar
Tommy Tommy is offline
Originally Posted by Gaz64 View Post
That is a dry twin disc clutch. Works with the same principle as multiplate wet clutches in Automatics or motorcycles. The "Steels" are the driving member, the "Frictions" are the driven member.
The more plates you have, the more torque capacity the clutch has. Automatics have 6 or more plates per stack, since they need to get the torque capacity in a small package.
Let me be sure I've got this. The black ring attaches to the flywheel and the metal disc between the two friction discs so those three metal parts turn as one. When the clutch is engaged, the forward friction disc presses against the flywheel and the aft friction disc presses against the metal disc. Is that correct?
Tommy
Previously owned EM Cobra
