Old 02-06-2021, 06:18 AM
Imlumpy Imlumpy is offline
Cobra Make, Engine: Antique and collectibles
I can’t offer any suggestions, but I can tell you it should fit , I have a 428 , edelbrock intake and long oval air cleaner and it all fit , had a Holley carb on it originally and even had a 1” spacer between the carb and air cleaner . Now has fitech fuel injection , no spacer under the air cleaner , it’s not even close to the hood .I have edelbrock heads , which are the same as medium riser Ford heads , the only thing I can think of is that the two four barrel intake situates the carbs higher than a single 4 barrel.although it ends soon , there’s a a@c car in eBay , it has an fe motor with two four barrels and a long oval air cleaner . Look for the listing , it’s white with blue stripes . There are under hood pictures .
