Old 02-08-2021, 08:20 AM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
This is from mine that shows an example of the fuel distributor mentioned in the prior posting from my SPF.
Unfortunately Dan, I do not have a picture of a COUGAR lettered intake for you.
Jim
An original unrestored 1963-64 water neck and fuel log assembly made in the Shelby American race shop. We are using this piece in our red car. This was not the only version.
I did not want to run without a thermostat (wanted flow control and temperature regulation). A version of Ford tractor thermostat can be modified to slip inside the upper radiator hose in a few minutes. I also added a polar array of tiny holes around the mechanism to allow air to pass when refilling the cooling system and coolant to pass low flow all around the thermostat during engine warm up.
Dan Case
