Old 02-08-2021, 01:56 PM
cycleguy55's Avatar
Originally Posted by Steve Gallegos View Post
Ok guys, I installed the mechanical switch, did not work, I reconnected the original brake line to the switch on the reservoir , it doesn't work. Do I need to replace the switch? Fuses are good.
When you use an electrical tester, do you have current between either of those leads and a good ground? If not, then you'll have to trace the circuit back to the fuse box.
BTW, when I first received my car (not a BDR) the stop light switch only worked when the ignition was on. Obviously that would be an immediate failure on any safety inspection and one of the first deficiencies to be addressed.
Brian
