  #34 (permalink)
Old 02-14-2021, 09:30 AM
spdbrake spdbrake is offline
Originally Posted by cobrasc1966 View Post
I use the AC Delco filters, and have a dual mount. These filters deliver consistently higher oil pressure than any others I've tried - Fram, Purolator, Motorcraft, Wix. And they're good filters.
Just a note. Higher oil pressure on one filter VS another points to a restriction in flow. It's not the pressure itself that's the end all, but the sufficient flow volume to all areas needing lubricant. Just the same as having your thumb over the end of a water hose. Pressure and velocity increases and gpm drops.
Not throwing rocks at your choice of filter(s), more of an observation is all.
