Old 02-21-2021, 07:35 PM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
Originally Posted by twobjshelbys View Post
Don't hook up the oil cooler unless you track the car. With the size of the radiator the engine is already over cooled. If you do hook it up put in a thermostat bypass
Any reason you're rebuilding the engine instead of just getting a new one? You have no idea what can of worms is in there. It sounds like the car was rode hard and put up wet and a rebuild that will discover and repair all the abuse it's seen will be as much as a new short block. And you won't be revisiting it again in two years
The engine in the car was the "born with" engine and the shelby alloy block was chosen specifically for the CSX part number which is a partial VIN match to the car. If it's possible to repair it, I want to. If it's so far damaged that it's unfeasable to repair and make it reliable I'll put a new short block in it. Barry R will let me know once he has it apart.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
