Old 02-21-2021, 07:06 PM
spdbrake spdbrake is offline
Originally Posted by d_ford View Post
Does anyone have any info about the "stratoflex" type braided hose used for fuel lines? I don't know if that was supplied by SA or the dealer, or if the original owner sourced it. If it's safe to use I'll replace the burned/brittle hose and re-route the line away from the exhaust.
Strat o flex is a Aerospace division of Parker. Typically you'll see them installed some where on about every aircraft flying. There is usually a metal band on the hose outer covering with the part number of the assembly etched on it. The PN can be broken down in the hose type, ID, length and end fittings. The hose end they use are MIL-SPEC and are reusable. You can rebuild what you have with new hose of the same construction and ID. It does not have to be the same brand.
