Old 02-21-2021, 07:43 PM
d_ford's Avatar
d_ford d_ford is offline
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
Originally Posted by spdbrake View Post
Strat o flex is a Aerospace division of Parker. Typically you'll see them installed some where on about every aircraft flying. There is usually a metal band on the hose outer covering with the part number of the assembly etched on it. The PN can be broken down in the hose type, ID, length and end fittings. The hose end they use are MIL-SPEC and are reusable. You can rebuild what you have with new hose of the same construction and ID. It does not have to be the same brand.
I called it stratoflex because I used to make hoses for the heavy truck industry with spin on fittings that were exactly like these. The hose I used to make were for oil lines and I had just never seen it used for fuel lines. I was concerned about how brittle the damaged line was although I'm sure it was due to being so close to the exhaust. I'm just trying to find out if it was a factory setup or not and if not, is it safe to use as fuel line.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
