Old 02-28-2021, 01:59 AM
RallySnake's Avatar
RallySnake RallySnake is offline
The critical thing is that the pivot points of a steering rack must line up with the inner pivot points of the upper and lower A arms. If they don't, you will have very bad bump steer problems.
You should post some pictures of your front suspension in hopes that someone will be able to identify it and help you find the right rack. If it's a Mustang 2 suspension, then the problem is easily solved.
RS
