Old 02-28-2021, 05:31 AM
Roylerumble Roylerumble is offline
Rally Snake,
the kit came with OEM lowers, but does not have uppers. I've been reading on here about the different widths of factory vs. aftermarket, and upgrading, and think (still have to do my research, so correct me if I'm wrong or you have a suggestion) that I will use Heidts package (link below) and QA1 coil overs, after I lower the upper mount by lowering it 2.5". I'm reading about the issues ppl have had with clearance, travel, shock/struts making contact, diameter of the bolts, not matching, geometry. I'm really hoping to NOT have to do a ton of fabrication to the frame. The kit is still in storage 400km away and I'm waiting for good weather to pick go pick it up.
https://www.heidts.com/part/plain-tu...tabs-ca-112-m/
