Old 03-01-2021, 06:46 AM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
Not saying your shop is completely wrong, but I do have to question what they see with your car. Do they understand it needs a Mustang II rack and not a Fox Body rack? There are two different MII racks available for hot rods. One has only one set of bolt holes, the other with three holes to be compatible for either hoice.
I also have a 91 CR1. It has all stock Mustang II front suspension and manual steering rack. The Mustang II geometry is some of the best designs at a reasonable cost ever put into a production car.
And though many folks have replaced the UCA & LCA's with aftermarket pieces, unless you are going road racing, its not really necessary. Remember the suspension was designed for a car almost 800 lbs heavier than our cars. The important part is to make sure the rubber isolators and bushings are in good shape.
Are you going to run a small block or big block? If you go the big block direction, you may want to consider power steering. Also, the aftermarket racks do come with specific dimensions for the mounting bolts. I have a Locost 7 I am building and it has a R&P from Speedway. The only thing funky about it was the tie rod end thread on the rack had a different thread than stock and when I needed different tie rod ends- it is not compatible.
Last question do you have the assembly manual with the car? I believe you an find a digital format of it on this forum. Though it is not the best, it does have a lot of the all outs for what parts you need. If you need something specific let e know and I can try and answer you.
Thom
