Old 03-01-2021, 07:54 PM
eschaider's Avatar
Originally Posted by Gaz64 View Post
If the crownwheel is splashing oil up to the FITTING on the diff housing, it will pump oil up a tube as the pressure increases from temperature ...
This ^
Inadequate cooling along with internal oil splash is frequently the culprit. A flexible hose to an overflow / expansion tank will fix your problem without going to the expense of an oil cooler for the diff.
That said if the internal temps are getting high enough to force this leakage problem, it could be to your advantage to use an oil cooler for the diff.
Ed
