  #23 (permalink)
Old 03-02-2021, 05:18 AM
blykins blykins is offline
Originally Posted by xb-60 View Post
So that's Jerry, Brent, Gary, Patrick (and me). I've not seen that much support for solid flat tappet cams in one place fora lot of years.
edit: and Fred
Cheers!
Glen
Well, I will say this....if it were a drilled block, I would be a little more favorable toward a solid roller with pressure fed lifters. Most Cobras don't see enough miles to wear a high dollar set of pressure fed lifters out.
However, if the block isn't drilled, there aren't too many choices and a solid flat tappet was made for that scenario.
I have my solid flats made a little differently than most guys though. They are nitrided, I use tool steel lifters, and I have them ground with extra lobe taper.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
