Old 03-04-2021, 08:52 AM
bobcowan's Avatar
bobcowan bobcowan is offline
You need either a thermostat, or a restriction plate. If you leave those out, the water moves too quickly through the system and doesn't transfer heat. The water temperature will look good, but the heads will overheat. And that's a bad thing.
If your fuel mixture is too lean, or the timing is incorrect, it will run hot.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
