  #21 (permalink)
Old 03-04-2021, 08:16 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
It is most likely that you have the idle set to high....with the idle screw that adjust the plates.......set the throttle plates first.....they should just uncover the transition slot.....and then you are supposed to adjust the idle via the idle screws .... The main idle ...screw ...is know used to get it final......if the idle mixture and transition circuit is set correctly it will not do that......1100-1200 is too high...it should still idle under 1000.
