Old 03-06-2021, 07:28 PM
CoyoteCobra CoyoteCobra is offline
Cobra Make, Engine: A&C, 2nd gen 5.0 Coyote, XAct Cromo light flywheel, TR3650, 3.25:1 LSD
Well, narrowing the axle would make the issue worse since that would make the rim get even closer to the inner fender. I added a small spacer to push the track out, and that's largely fixed the issue but I hate using spacers if I can avoid it. Replacing the custom welded wheels would be an option but it would be much easier to cut the fiberglass and tweak the inner fender a bit (something I may end up doing).
