Old 03-10-2021, 11:17 AM
sgianino sgianino is offline
Cobra Make, Engine: era#671 Keith Craft Motor
I don't think so, I think they'll just drop right in to the 7" bucket.
Hi Patrick,
I went to put in the new PL700, even with the trim ring fully tight the bulbs are loose...would you use a rubber shim behind the Lucas tabs or shim the trim ring against the glass of the beam?
Or are there different trim ring sizes? would that be a better bet, maybe one that is not as deep that came with the car...Wasnt sure if all trim rings where the same,
Thanks
