  #26 (permalink)
Old 03-17-2021, 04:22 PM
chucks1's Avatar
chucks1 chucks1 is offline
Cobra Make, Engine: SPF, 395 Stroker
Originally Posted by Moritz55 View Post
Chucks1, when you install the new one.. start the car and see if you are getting 14.5-14.7volts at the battery. Once engine idles normally (800-900rpm) and fully warmed up with lights on and fans running .. you should see ~13.0-13.4volts at the battery.
Just confirm the alternator is putting out nicely and well grounded .
Useful link: Voltage drop when the fan is on
Many thanks.....
Thanks for the suggestion Mark. My last battery was actually still good (although 10 years old) so this replacement is more of a preemptive strike than anything else, but I'll definitely check the voltage once I'm ready to actually start the thing up.
