Old 03-19-2021, 07:32 PM
Jeff 427's Avatar
Jeff 427 Jeff 427 is offline
Cobra Make, Engine: Unique 427 S/C - 482FE built by Survival Motorsports, 4 Spd. Toploader, Jag 3.31
Thanks
8Litercobra never checked the Jag rear but I want to get that done also.
Got the specs. from Alan and I had the front end done after I finished the car in 2006. Alignment shop could not set the caster on the left side?
Spoke to Alan and said to send him some pictures of the suspension with the tires off and he called back and said that upper control Arm was wrong,
it was for the right side and you would never be able to get the correct caster adjustment.
He sent the correct Arm I put it in and did "home" alignment by eye in my garage, not real accurate but it did the job.
I will leave it to the professionals this time!!
Hey Dan could you give me the tech's name at Gunnels?
Thanks
Jeff
