Thread: What Pedal Box?
Old 03-20-2021, 10:01 AM
Roylerumble Roylerumble is offline
Originally Posted by Lightingrod View Post
The pedal box was from CR II but it was a cable setup like a Fox-Body!
I would go with an after market complete pedal assembly! Wilwood or some other after market brand!
https://www.jegs.com/i/Wilwood/950/340-12411/10002/-1
I have to do a bunch of research on this topic to determine if I want to go cable or hydraulic clutch, stay with drum in the rear or upgrade to disc in the rear (prob go that route now as apposed to later), and address the accelerator pedal now. Id love to see what other build used in regards to floor mount, reverse swing, firewall mount, upper mount, etc. I like those wilwoods you found. I also found these
https://www.usrpc.com/product/revers...nder-kit-6-21/
and these
https://www.usrpc.com/product/revers...er-pedal-6-21/
What was the ratio that should be used? I recall reading 6:1
