Thread: 5.0 EFI on CR1
Old 03-31-2021, 08:51 PM
Roylerumble Roylerumble is offline
Originally Posted by Horseracejudge View Post
Hi Chicagowil,
This is a 302 with 94-95 GT 40 option upper & lower intake with a 3/8 spacer. 65 MM throttle body with the bend. The clearance is close with hood. Couldn't use a thicker spacer. Pan clearance is ok. Using a Canton street double hump with a rear sump. Nick
older thread, but had issues with the motor mounts. Discovered that the part number for the mounts in the manual are discontinued. The shop found a set that worked, I believe they reversed them and had to redrill the pass side. they have the horizontal bolt through them. Anticipating hood clearance issues after reading posts.... @Horseracejudge, what motor mounts did you use?
