Old 04-01-2021, 08:38 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
I’m using a McLeod clutch too in my Big Block Ford application. I’m using a pressure plate MCL 360-850 and the clutch disc is MCL 260871. These were called 800 series back in the day Just make sure the diameter is correct for your application ( horsepower/torque) and the intended use; Racing or Street
The clutch disc I selected above for my Cobra has a little chatter upon engagement from idle speed due to the friction materials I selected. Raising the revs to 1200 rpm and slipping it a bit gives smoother engagement and less chatter. It’s a performance clutch so there are trade offs for driveability.
"...some assembly required, ages 8 and up...... well that took longer than expected......
