Old 04-04-2021, 02:27 PM
patrickt patrickt is offline
Originally Posted by fastd View Post
Ok. Thanks. The part number is different; I think I’m gonna go with red line; not easy enough to find the Amalie
Separate question: anyone have a part number for the differential drain plug for the ERA with a jag rear?
Use the GM Limited Slip Additive Part #1052358, now #88900330, (I use about seven ounces total) and a quart and a third of Moroso Climbing Gear Lube Part #34800, which is red in color. Do NOT remove the lower plug to drain the fluid. Instead, suck it out of the fill plug. I use a Plews 55001 Lubrimatic Fluid Quart Pump and surgical tubing.
