Old 04-12-2021, 02:43 PM
NROTOXIN NROTOXIN is offline
Cobra Make, Engine: SPF832, 466cid
Originally Posted by ERA 626 View Post
I am running 0 toe in the front and about 3.5- 4 degrees castor 25 psi front and 28 psi rear on billboards. I have checked several times the suspension components, the car seems very tight on the road. It seems like the tires are causing a shutter in the front end around 75MPH.
The problem is that every time I want to make a change to the castor I need to take it to the alignment shop. I can easily give the heim joint a turn on each side to see it this helps but I dont know what affect this will have on the rest of the geometry of the front end? What do you do at the track? this is a CSX car so its very easy to make adjustments.
Mike,
Where in the bay area did you go to get your alignment done?
