Old 04-15-2021, 02:36 AM
EM-0785's Avatar
EM-0785 EM-0785 is offline
Senior CC Premier Member
Cobra Make, Engine: Everett-Morrison 514, Toploader 4 sp, Jag IRS
You mentioned you want single adjustment coilovers. If so, the QA1 part number scheme has the same numeric portion but with the letters DS in front for single-adjustable (DD for double-adjustable).
QA1 tech support can also walk you through the decision point considerations to verify in your application if helpful (measuring, end types, spring length, axle weight, etc.). Best of luck. Brent
