Old 04-23-2021, 05:04 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Earl J View Post
Hello Jim,
I currently run 48 IDA’s on a 65 GT350, I’m up in Northern NY originally from the SF Bay Area CA. Few Questions for you what are you running for:
Size Venturies/Chokes?
Emulsion tubes?
Air Correctors?
main Jets?
Idle Jets?
ByPass Jets? (At the bottom of the bowls)
Discharge nozzles?
Most importantly, are your floats (fuel level adjusted properly)?
Fuel pressure no more than 2.5-3.0 psi
Cam Shaft lobe seperation?
Sorry for the long list, but I need to know in order to help you.
~Earl J
I think Jim is asking about Redline EFI, not Weber IDA carbs.
Gary
