Old 04-27-2021, 09:34 AM
cobrarkc's Avatar
cobrarkc cobrarkc is offline
Cobra Make, Engine: Contemporary 482 all aluminum Tunnelport Self built and owned since 1980 frame#0000017 and owner of frame CCX 33961 looking for an FIA body to go with it
If you take the driveshaft off you can slip the transmission back enough to take off the bell housing and service the clutch. to get the trans out you will then have to lift the engine up in order to slide the trans out. The newer frames have the flanged cut out on them.
Cobrarich
