Old 05-02-2021, 05:32 AM
Soundkillr Soundkillr is offline
Cobra Make, Engine: Backdraft cobra FE big bock
Originally Posted by scootter View Post
I would not think you are running out of air. Sure you are not running out of fuel? I had the same air cleaner on my 514 but with the K&N filter and it was fine. Recently switched to get some more air and let the heat rise out better. I also tried running my without the PCV valve, and that did not work well.
New one.
Old one
Also...I like your throttle spring return set up. Can you tell me where to get that style arm and springs? Much better solution than what I have....
