Old 05-02-2021, 09:14 AM
tortuga tortuga is offline
Default Throttle return spring
Originally Posted by Soundkillr View Post
Also...I like your throttle spring return set up. Can you tell me where to get that style arm and springs? Much better solution than what I have....
Had a very knowledgeable carb tuner point out that the return spring should work against the pull of the throttle from the opposite side, otherwise you are loading up the throttle blade axle all in one direction.
OP think you are running out of fuel. I agree, pop the air cleaner off for two minutes in a clean area and see...
Superformance 1764
Built 427W
Aiken SC USA
