Old 05-11-2021, 02:02 PM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Edelbrock
In tanks are the best solution these days imo. If you want to keep with an external pump, im using this Edelbrock pump. Its high quality and a little quieter than most and has an internal regulator that is adjustable! Its set at 6.5 psi for their carbs but Im able to adjust it from 5-8 psi in my experience. Im running an Edelbrock carb with it. I have a new build with 800 ish miles and its a great pump so far. Edelbrock also sell a service kit for the pump when its time to replace or clean the internal stainless screen. Its a well designed pump and even though Ive only got 800 miles on it. its nearly 13 years old
https://www.edelbrock.com/quiet-flo-...-gph-1791.html
"...some assembly required, ages 8 and up...... well that took longer than expected......
