Old 05-15-2021, 01:02 PM
mutt mutt is offline
Thanx for the help...stuck clutch disc as suggested.
Had car on lift. So, moved it to back of lift, put it in reverse, had helper put the clutch in, and pushed it down the ramp. At first, it didn't want to break loose, but then it broke loose and hung up again. Repeated pushing with clutch in and it appeared to break loose a little more.
Pushed the car in neutral back about 20' from garage, connected car to the winch I have on the front of the lift, put it in 4th, put clutch in, and pulled car with winch feeling it continuously breaking loose. Repeated this in 3rd, 2nd, and 1st.
Car then cranked normally with clutch in in all gears.
Did notice occasionally that car didn't want to go into gear with clutch in motor running, so pumped clutch and that alleviated the problem. Have bled slave a number of times and it is getting full motion when I watch it with helper pushing in clutch. Will have to figure this out next.
Thanx again for the help!!
Next clutch task...replace Ferrari Boxer slave and slave hydraulic line.
Then figure out GT40 clutch issue. No clutch pressure whatsoever.
