Old 05-28-2021, 09:57 PM
MGM MGM is offline
Both of mine are to the right of the steering column, quite hard to see. Yours may be different but probably in the same spot. I find it easier to pull the drivers seat out and then you can lay on your back with your feet up and head under the dash. Good flashlight will help. I’m sure you’ll find it.
Had to swap mine 10 times trying to find one that would work with LED bulbs.
