Old 05-30-2021, 09:45 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
You drill holes at the ends of the crack before welding the crack up, to remove the end of the crack, so the crack can't continue to crack in service, after the welding is done.
The crack is still evident under the weld if the ends of the crack aren't drilled.
Gary
