Old 06-04-2021, 03:54 PM
KarlzEE Bebout KarlzEE Bebout is offline
Bruce, if its just a minor coolant leak, I'd dump in a tube of AlumaSeal. I've been using it for literally decades with good results. It won't clog the cooling system, is a water pump lubricant and an anti rust. If it doesn't do the trick, you'll be out $5. It will not stop water pump shaft seal leakage or hose issues but is pretty wonderful on little gasket leaks and radiators. My 2¢ worth.
