Old 06-05-2021, 06:54 PM
eschaider's Avatar
Dan,
If you have an OEM ECU and it sounds like you do, a tuner can disable PATS in the engine's tune. Not just because of PATS, but a whole range of other issues, if I were you I would replace the OEM ECU with a modern aftermarket EFI ECU. Both you and the engine will be much happier.
Ed
