Old 06-07-2021, 12:19 PM
Austin_Snake's Avatar
Austin_Snake Austin_Snake is offline
Cobra Make, Engine: Exact 427 Carbon Car
So I installed a fan wiring kit from Painless Performance and came with a switch that operated at a set temperature range. They offer different ranges so you can get your fans to run at the correct temps. Sensor just screwed in where the existing temp sensor went.
Though I am not sure why you want it to run after the engine turns off. Where I live it gets pretty hot so when I'd get home the fan would run way too long and eventually drain the battery. The water is not flowing and the block is just soaked in heat. I rewired it to my Ignition so it goes off with the key.
Good luck,
Richard
