Old 06-08-2021, 05:14 PM
MOTORHEAD's Avatar
MOTORHEAD MOTORHEAD is offline
Cobra Make, Engine: KIRKHAM 427 S/C, SHELBY 427 ALUM. STROKER
Default Clutch linkage FE w/ toploader
Tried the old McCloud hydro T.O. brg as a last resort, as the mechanical set-up
was not good. The hydro unit started leaking almost imeadiately, so tranny is comming out for the third time in the last 6 mo's !
the problem with the mech set-up is the tranny has the big input shaft, so the nose piece tube that the t.o.b slides on is too big for most bearings. So Mcloed had provided an altered press plate with the fingers cut back to enlarge the hole to clear the tube..but the shorter arms increase the amount of force needed to operate the clutch. I need something better, and I know there are kits out there, but will they solve my problem ?
I 'm sure there are members who have had the same problem, and I'm hopeing
they will see this post, and reply.
"When Injustice becomes Law,
Rebellion becomes Duty." T. Jefferson
