Old 06-08-2021, 06:03 PM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
More info is needed, is your fan a pull through or a push through, are you running a shroud, any idea what CFM the fan is, 16 inch fans have different flow rates, whose manufacture. Does the temp go down once you start moving? Are you running an under drive pulley on the water pump? If you are not running a shroud that would be the first place I would start.
Bill K
