Old 06-13-2021, 07:40 AM
grybrd123 grybrd123 is offline
Cobra Make, Engine: N/A
I've posted photos of the dash arrangement in my Gallery. The binnacle will have speedo, tachometer, oil pressure and coolant temp, plus the two LED turn signal indicator lights on either side of the upper small gauge. Center panel will have fuel, volts, and oil temp. The clock, which is slightly larger than the smaller gauges, will be above the center gauge and not in the panel. On the right is map light and switch, on the left is panel light rheostat. In the center below the dash will be the heater and A/C controls. The black control panel with levers and pull knobs is from an MG.
