Old 06-13-2021, 04:16 PM
ERA 626's Avatar
ERA 626 ERA 626 is offline
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
Originally Posted by bkozlow View Post
Generally, it is three words written on the relay "MADE IN CHINA" and if it is Bosch then your amp rating is to low. I would go to a German car dealer in your area and have the parts department find you a HD unit for one of their top model cars, more than likely they will be Bosch no matter what type car. Or you can contact Texas Industrial Supply at texasindustrialelectric.com/relays and look over their inventory. Look at 0332-002-168, if it were to fail then you have other problems in your system.
Bill K
he beat me to it... "made in CHINA" all joking aside you cant simply throw a higher current relay at the problem. If that is the case than you will need to confirm that the size wire/fuse is of the correct size to handle the load of the fan as well or bad things may happen. Better safe than sorry. Sorry I am an electrician by trade.
