06-16-2021, 02:16 PM
CA
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
It should be fairly easy to figure out where the issue lies. if its the body being off or the rear end being off. Measure from a point on the rear suspension like the brake rotor to the chassis on both sides, it should be the same. I also assume you tried swapping the wheels to confirm it is not an offset issue. I am not familiar to the backdraft rear end. but you should be able to figure it out in a few min with a tape measure, measure the brake rotor to the chassis on both sides.
