Old 06-21-2021, 12:43 PM
rbgray1's Avatar
rbgray1 rbgray1 is offline
I made upper and lower mounts for the rear coil overs our of 3/16 cold rolled steel, had a steel shop bend them and drill holes. cost $25.
I then welded the new mounts to the upper chassis mounting point and the lower to the third member mounting area.
I also gusseted with 3/16 CRS the upper and lower area to handle the weight etc .
All very simple!
I wouldn't use the long bolt type of mounting the coil overs, there is a very large amount of stress on those mounting areas.
