Old 06-22-2021, 09:46 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
I saw it like this...when I ditched the spring perch and installed the coil overs purchased thru CRII right before they closed I was provided with a spacer and long bolt to attach where the shocks originally attached to the chasis. That put 100% of the load on 1 bolt per side. Looked like failure waiting to happen. So I designed a bracket that i could install (not being a welder) that would beef up the shock mount. Double shear, not single shear. I also added adjustable upper and lower control arms to adjust the pinion and alignment. Pictures in my gallery.
John
