Old 06-26-2021, 04:48 AM
patrickt patrickt is offline
Originally Posted by Moriarty View Post
I Do I tape off both the red wire and white wire on the driver’s side, and then use the other two to trigger the two relays? Presumably matching red with blue/red and white with blue/white, if I had things right above?
Yes, cut and tape off the original feeds to the driver's side lights, both high and low, and instead feed them from the relays that will also feed the passenger side lights. You do the same cutting on the passenger side, but those feeds will then act as the trigger wires for the relays.
