Old 07-03-2021, 03:45 PM
patrickt patrickt is offline
Originally Posted by Moriarty View Post
Finally got around to tackling this. Not as clean as I’d like, but everything worked first try, so that’s good. I’m guessing I should probably put some lower amp fuses in than the 30 amp ones they came with?
Getting it to work right is 95% of the job, making it look trick is only 5%, that looks just fine to me. And a 30 amp fuse is good -- if you short on something that'll blow before the wires melt, which is all you want. Good work.
