  #21 (permalink)
Old 07-03-2021, 07:22 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Red wire to first relay and double crimp a second wire jumper to the second relay at the first relays connector. Will really cleanup the installation. Black heat shrink material on all wiring, just don’t heat shrink it. 90 degree wire splices, not good looking. Once again double wire crimped at connectors make nice splices, loose all the multicolored electrical tape, electrical tape is for houses. (And wire looms) Solder connectors when necessary. If you are going to splice two wires together, they should run parallel, and be soldered. Get multiple sized rolls of heat shrink tubing, (Harbor Freight sells them) split larger tubing and insert smaller tubing at branch locations. Everything black will disappear under the hood.
Blas
SPFWiringDiagrams@Comcast.net
