Old 07-08-2021, 10:49 AM
Quentin Z's Avatar
Quentin Z Quentin Z is offline
Cobra Make, Engine: Backdraft #272, 351W
Originally Posted by FredG View Post
You might want to consider replacing any rubber connections from the fill tube.[/url]
You definitely want to change the rubber connections! The fuel ate through mine and started leaking in a parking garage. Luckily the level wasn't too far past the bottom of the inlet, but messy none the less. I don't think "filler neck hoses" are intended to be in permanent contact with gasoline.
