Old 07-11-2021, 04:19 PM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Originally Posted by DonB View Post
Does it matter if dif is higher than trans? My engine drop is 3° down and my dif is 3° up but dif is higher than output shaft of trans.
Don,
Doesn't matter.
As long as the centerline of the pinion gear and the centerline of the crankshaft/trans assembly are parallel, the car will be fine.
The direction of the offset isn't a factor. Up or down, left or right - take your pick.
Tom
